Aftermarket Alloys
There doesn't seem to be many after market alloys available for the 197/200. My refurbed alloys are looking a little tired again so thinking about something different..
What are the options/cost? what should the pdc be? I know the size of the caliper limits options.. Not having much luck searching through the internet! Cheers guys.
my summer wheels are clio v6 5 stud fitment.
you need 5 x 108 pcd
et 68-45
centre bore 60.1 (but you can spigot rings to make the wheel centre smaller)
I think all these cars had 5x108 fitment, so it's worth a look:
ALFA ROMEO 166 99>
CITROEN XM 89 >00
FIAT SCUDO 07 > only
FORD FOCUS MKII 04 >
FORD FOCUS ST 04 >
FORD C MAX 11 03 >09
FORD GALAXY MKIII 06 >
FORD KUGA 08 >
FORD MONDEO MKIII 00 >
FORD TRANSIT CONNECT 02 >
FORD S MAX 06 >
JAGUAR XF
JAGUAR S CLASS 99 >
JAGUAR X TYPE 01 >
JAGUAR X CLASS 01 >
JAGUAR XJ8 SERIES 03 >
JAGUAR XJ SERIES 03 >
JAGUAR XKR 06 >
LAND ROVER FREELANDER MKII 06 >
LANCIA KAPPA 95 >
PEUGEOT 607 04 >
PEUGEOT 605 89 > 99
PEUGEOT 407 04 >
RENAULT 21 TURBO 88 > 98
RENAULT SAFRANE 92 > 03
RENAULT LAGUNA 94 > 01 5 STUD
RENAULT SCENIC RX4 00 > 03
RENAULT AVANTIME 02 > 03
RENAULT ESPACE 92 > 03
RENAULT ESPACE 03 >
RENAULT MEGANE RS 04 >
RENAULT MEGANE MKII SPORT TOURER 07>
RENAULT MEGANE MKII PHASE 2 07 >
VOLVO 850 96 > 00
VOLVO C30 06 >
VOLVO C70 06 >
VOLVO C70 COUPE/CABRIO 97 > 02
VOLVO S40 04 >
VOLVO S60 00 >
VOLVO S60R 00 > 07
VOLVO S70 97 > 00
VOLVO S80 06 >
VOLVO S80 98 > 06
VOLVO S90 24V 97 > 98
VOLVO V50 04 >
VOLVO V70 97 > 00
VOLVO V70 XC 00 > 05
VOLVO V90 97 > 98
VOLVO XC 70 05 >
VOLVO XC70 MKII 05 >
VOLVO XC90 02 >
Cool, thanks! But doesn't the clio have an unusally high offset? ruling out most the wheels that fit the above cars?
I guess if you want just looks, every wheel not too wide with an offset of 40 or higher (way more common than the ET68 of our cars) would fit the car without rubbing the arches, but as some people say, spacers ruin the suspension (that's what I've heard, I haven't tried) so maybe that problem will arose with one of the above wheels
brad197 is right, Clio 197 got a very rear stock wheels offset - 68. Volvo and Ford some near by (52-55) But even O.Z. made the wheels 8x17 with 55mm offset for Clio.
You can go for:
Turini 7x17 = 6.9kg
Alleggerita's 8x17 = 6.67 kg
Ultra's 8x17 = 7.7kg
Kosei OP Magnum 8x17 = 8.5 kg
Enkei J10 = kg?
8" wide with +48mm offset = what size equivilent spacer?
7.5" wide with +45mm offset = 23mm wider
the wheels ive brought were 45mm offset, can say, it hasnt made the car handle worse but has improved it.
Raptor will the enkei fit straight onto a cup without any spacers or that
If my calculations are correct and the wheel specs are: 7x17 ET 38 vs 7,5x17 ET 68 stock, your wheels would be 24mm more on the outside, and you would have 36mm more inner clearance (the inside of the wheel to the strut housing).
IMO, the tyre might rub when going over bumps on the road, especially if lowered...
