ABS “Abnormal voltage”
HarryJT97
Okay so I am absolutely stumped, I have an issue with my 200 Meglio at the moment where it is bringing up an ABS issue for seemingly no reason. When plugged in to clip it gives the error message “abnormal voltage” and nothing else. No error codes, nothing. I have checked everything I can think of, the car has had a new ABS module, and has had data logging that shows all 4 sensors are working as they should be. So it’s not sensors and it’s not the modules and I’ve checked all fuses.
Alternator has been checked and showing no charging issues, battery has been changed, still the same issue. I just cannot find anything anywhere that seems to fix this issue. Is there anything that any of you know of to check that could be causing this? As it is driving me nuts. Or any suggestions of what to potentially check.
