Performance isn't just gained by enlarging the inlets and exhaust, you want the smallest throttle body, inlet manifold and exhaust system that is big enough. You want as much air in and out as possible but you also want the air to flow as fast as possible. And a certain amount of air flowing through as 60 mm hole will be travelling faster than it would through a 64 mm hole.
