As per the title?? Are they the same I.E. could they be straight swapped? Cheers
shakey_hand_man Jan 26, 2011 #1 As per the title?? Are they the same I.E. could they be straight swapped? Cheers
BenW Jan 26, 2011 #3 I think the head is meant to be different so would be worth double checking this
Foxspeed "the new red baron" Moderator Jan 26, 2011 #5 i have looked at both engines.....and externally i couldnt see any difference the heads are different but only internally - valve area/inlet throats
