Brunoandrade98
My (just under) 80K-mile Clio 197, the gift that keeps on giving...
Two weeks before a road trip, the car has developed a bit of a stutter (maybe misfire)...
Engine is on low compression across all 4 cylinders, 120 PSI each. Feels low on power, but has run smooth so far. I did have a lot of shudder that felt like a lumpy idle, but it turned out to be a lower engine mount that had completely disintegrated after about 10k miles...
When driving normally, the car can stutter momentarily at any speed/gear, more noticeable going uphill.
It’s been to a garage recently for another wet & dry compression test and a quick safety check. I’m going to check for oil on the spark plugs, which I’ve seen before in small amounts and could cause ignition issues.
Other than that, is there anything else I can check?
Spark plugs are less than a year old. Coils are a possibility, but tested good a couple months ago.
Any input appreciated.
On a side note, if anyone has an engine for sale, I’m absolutely interested. Closest to Wrexham, the better, but will travel for the right engine.
