Clio 3 rs200 track geometry shims
Rs200rich
Hi all, I need to buy shims for the rear on my 200 track car question is which ones will I need? Believe they run around 1.5 degree neg standard was going to run 2.5? What about toe? Thanks in advance for any reply’s
You’ll need to get the rear Geo’d to find a base point to know how much camber shims you need
If your car is lower than the standard ride height it will have changed the standard rear camber of minus 1.5 degrees and may have more negative rear camber.
Reactions: Rs200rich
Like Beany said, you need to get the geometry done first to establish what you’re working with, and then compare that to your target setup to figure out what combination of shims to buy. Anything else is just guesswork.
