Seat belts - Yellow
Thanks guys! Just got myself a 200 full fat cup in white with some recaros! Needs a bit of tyding up but a fun project.
deffo keen to go to some meets in the summer!
Any other must have mods shout!
Hi, thinking about swapping my standard silver belts foa set of these yellow ones. Was a bit concerned about a tensioner plug? If it is as easy as a plug and go I’ll get some.
Any advice gratefully received, thanks.
I would make sure you have a radio code and disconnect the battery for around 10mins before you work on any airbag.
People so you dont have to and say its not needed but for me when I do alot of work on the car the battery is disconnected through good practice
Thanks for the advice. I ah e disconnected battery and got one side stripped. Will take the others out this weekend and get them sent away. Will post a picture when they return. Cheers. Ean
