What wheels do you have?
Bro
Just wondering what wheels everyone has?
I'm looking for some non standard wheels but I'm struggling to find the right offset and width
Do you get any problems with having such a low offset? I've seen a lot of wheels available with an offset of 35 but thought this was too low
Not had any issue's myself. Only running a 215 tyre. If I was to run a bit of camber could probably get the 225's on. It's on H&r springs.
I haven't driven it on anything else so unsure if it affects the way it drives?
Reactions: Bro
Are you thinking of track days Mark?
Be interested to see if they rubbed!
I have bought OZ Ultraleggeras, with Michelin PS4s.
Specs:
Wheels:
8X17 ULTRALEGGERA MATT BLK 5X108 PCD ET55
Tyres:
225/45ZR17 94Y PILOT SPORT 4 XL
No spacers required, fills the arches nicely, but you could put a 2mm or 5mm if you wanted to push them even further. Hope this helps :smile:
53F16D91-56FC-4BC3-973A-1FF6100D11DF.jpeg BC33162D-52D7-4D2D-A888-88A879769D0D.jpeg
Reactions: Bro
