Front shock absorbers part number?
Bro
Anyone know the part number of the front shocks on a 2006 197?
Renault parts direct as a member you get I think cheap or free postage and I don't think you will get them any cheaper anywhere else there are two types normal and cup the cup should have an orange sticker. As far as the car goes there are two types pre 2010 and post 2010 you will have the larger top mount and I urge you to check it first or change it anyway they tend to split and knock at low speeds but the split can only be seen when the weight of the car is on it's wheels if you jack it up the split is pulled closed and you can miss it. A good pothole solid hit seems to be enough to split them so if you experience one and think that's got to have damaged something then check the top mounts they take the full vertical pressure.
