Bumper alignment
On my last 197 all I did was apply some heat (gently) to the bumper clip and bent it out a bit (makes more sense when you look at the set up) once cooled down it pushed back together properly and never popped out again.
There is a simple & easy fix for this, you have to wedge something between the black plastic support attached below the headlight and the front crash bar, this lifts the bumper up at the corner and holds it in place.
I will find a picture tomorrow so you can see exactly what i mean.
this there is a photo of it somewhere on the site - basically supports the bumper as it tends to drop and pull away at the sides so some very stiff spong type material is wedged in to stop it
Re adjust the headlight and check the bolts that hold the wing slack them off a bit move the wing out or maybe forward to bite the front bumper a little better.
ive tried realigning it all and moving headlights etc but your governed by the holes etc so shouldn't be misaligned as they can only go in one way,its like its dropped and popped out at the same time, really weird, is there a detachable fitting i can use to hold it in place that i easy to install/use to get the bumper on and off and fix this issue, it really makes the car look awful
