Y pipe gains (fitted and mapped)
hi all,this arrived a couple of days ago so i'm just after a bit of info on what gains i should be seeing,not interested in the flat spot as i've spoke to paul at RS Tuning and he's going to map it out,its getting fitted on the 16th so i'll report back any progress,cheers
Y pipe by scott1532, on Flickr
You keeping the secondary cat or just going all out catless.. Be interesting to see the results, should be good
think it through logically, the flat spot appears due to making more power/torque and the engine wanting more fuel at that point. That's the rev range where you're making gains
it is!
as for gains cannot say until its on the rollers and sorted can you:huh:
ktec quoted me 4-5 hours labour to fit as its a mani out job
it would sound ace though with my evo system
part + fitting + map = isnt gonna cheap
So you think adding more fuel is the answer ?
the right amount in the right place. I've not got full control of standard ECU's so I only assist and record data, request changes etc. However, we mapped out a flat spot on a cammed 200 with decat with mostly fueling correction only last week
interesting to know, so with this y pipe you would need to keep the secondary cat or fit a sports cat for MOT?
