Windows 8 Upgrade offer
M
Mentalpen
You just need to bend the truth a little.
http://www.windowsupgradeoffer.com/
select your country then go through the form like you just bought a new pc and it came with win7 on it. they will email you a coupon code that you use when you are about to pay for win8. make sure you input the code right before you click to pay. you have to use the upgrade assistant to purchase win8. also the upgrade assistant doesn't work if you already have win8 on your pc, it has to be win7 or older OS. also there is an option to make an iso in upgrade assistant and burn it to a dvd. So its great for a clean install. also after you get windows 8 installed, for a limited time you can get windows media center pro pack for free. here is the link
http://windows.microsoft.com/en-US/windows-8/feature-packs
it should be £70!
its only £24 for the download, but i cant get it to work, says not available in your country and therefore cannot upgrade :worried:
Where are you?
It should be open to all regions?
Have you tried lying?
Don't forget to download the free pro pack after. Think it's available until end of jan for free then £70 if you forget to do it.
