Which small battey??
as you said before the standard battery worked when you tried it with the same connections so i would rule that out.
hi mates!
with fully charge battery.... is NEARLY ok...
the car starts but with difficult..
i'll try to abbreviate positive cable.. now i've 150cm extra.. do you think can i resolve with this way?
oh.. i forgot to say you a very important thing!!
the problem with the standard battery was this................... i find it when i tried the new battery in the new position! i remove the bolt and the cable was crushed under it... so the dispersion created the problem...
the positive cable was crushed under this bolt! now i use this for negative..
:thumbup1::thumbup1:
Great - today I had a talk with my electrician when I had my new fog lights installed, and he said that you should check your cables. :thumbup1:
