Tutuur's Big turbo Clio R27
Yesterdays progress:
Fuel pump cover finished
New brakes and hubs fitted
Nice fit
Turbo oil return mocked up using 2 original return pipes and an aftermarket pipe
Reactions: Cossers and Beany
Have to say, I think the wheels do look really well on it, esp with the work that has went into getting them on! Just love the fact the owner seems to be doing it all himself, much respect
Cheers lads, i know they're not everyone's cup of tee as nearly all of you are into track driving. For my needs they are perfect though and i really fancy how they come out on the car.
Everything i'm able to do myself i will, machining work has been outsourced though as i simply don't have a cnc machine
A bit of progress again, my friend who was going to weld my v-bands didn't have any spare time so i decided to do it myself. With a few hints his side and using the alloy heatsink they turned out pretty well.
Exhaust is nearly finished now, just have to make two lambda bungs in the downpipe and redo the rear section mounts as i want to make them adjustable so i can level both tailpipes perfectly.
yet some more progress, pressure side of compressor housing custom made to suit standard boost pipes:
took a while to get everything lined up as the silicone hose only just fits between the coils!
lambda bungs added to downpipe aswell:
