Tutuur's Big turbo Clio R27
Cheers mate, first and second are a challenge to say the least, from third gear on your head will be planted against the seat! :smiley:
Reactions: Big Ben
A very good afternoon, a few months down the line.
Project is just awesome and an inspiration as I am in the planning phase to do something similar as well!! will be probably using a G25-550 as t/c and a racing ecu (thinking about)
just wanted to ask if you had any issues with:
1. gearbox. You are using the R26 gearbox...any issues you had with crunching gears or synchros?
2. cooling/temperatures either water or oil
3. clutch/flywheel
4. something else you would advise attention should be paid at?
many thanks for your input in advance... what a great car you built look and power wise! ..kudos to you Sir :smile:
