Should hopefully have some footage sorted later today from yesterday at Bedford. The car ran faultless all day. There’s no way I’m selling it now! Was absolutely flying.
Major difference being boosted!Should hopefully have some footage sorted later today from yesterday at Bedford. The car ran faultless all day. There’s no way I’m selling it now! Was absolutely flying.
004 TL4 gearbox mate. Perfect combination in my opinion. It still drives like a Clio but with double the torque!Damn that goes through gears quick! Are you still using the Clio box??
+1..glad you had a good time..just proves how capable the chassis is..Excellent. Enjoyed the session with the Focus
What length studs are you using?Decided to give the rear brakes an overhaul this morning. The calipers looked pretty good and the paint looked intact however on closer inspection it was clear that most of the paint had come away from the caliper with the other red paint falling off on touch.
The pads were a little worse for wear as well but the discs are like new with hardly any wear at all.
I cleaned the discs up and cleaned the calipers up too ready to give them a nice new coat of red paint. Really happy with the results.
I’ve fitted a new set of CL RC 5+ which I had on the shelf. These should offer much better brake balance from front to back since I’m running CL RC6 on the front.
Next job this month is to install a new lower ball joint on the NS.
Do you sell them?
It's heat resistant brake paint Mark. Thankfully I had a tin on the shelf and the finish was better than I thought.What paint did you use Matt?
Need some for the Golf as the new calipers came through silver instead of red.
It makes it much quicker and easier when changing wheels over mate since you have the studs as a guide.Is there any major benefit from using studs over traditional bolts?
Cheers mate I thought so..It makes it much quicker and easier when changing wheels over mate since you have the studs as a guide.
68mm Ben...If you could mate I’d appreciate it. Ktec sell 68 or 90mm. I don’t use spacers so guessing 68
68mm Ben...
Those are the ones mate but I don't have the locking nuts with mine.
S | Clio 197 in Racing Blue FSH 65k £5,500 | Clios For Sale | 1 | |
S | S88THL - Supercharged Clio 200 | Projects/Progress Threads | 3 | |
K | Ricambi tuning exhaust for MK3 Clio? | Clio 197 Area | 1 | |
C | Clio 197 alternator | Clio 197 Area | 1 | |
S | will a 197 diffuser fit on clio 200 | Body Work and Exterior Lights | 16 |
