Trackcar II
Discussion in 'Projects/Progress Threads' started by steqpenwolf, Sep 11, 2017.
  1. Slowride
    Slowride Paid Member
    17
    Clio RS 197
    I've seen many vids of your ring laps, respect. Nice to read what you've Done already to your car, like it very much.
  2. ///M
    ///M Gold Member
    R27, ///M CS, Exige V6
    BLOODY HELL!!!
    What a thread! BTG time is very good. Hats off to you for all this work. Hope you're happy with it.
    Superb thread!
  3. steqpenwolf
    steqpenwolf Paid Member
    31
    Nordschleife
    Clio 3 RS
    Hello Peter, it is a torsional differential of wavetrack from USA. 2 years ago there was a collect order in the german cliors.de forum. but I would like to exchange this this winter against a Drexler diff
    peter likes this.
  4. Sean197
    Sean197 RIP Albi :( Moderator
    Fife, Scotland
    Albi 197T - RIP, MK7 Golf GTD Sports Wagon
    Have you thought about fitting a Megane turbo engine rather than another Clio one?
  5. peter
    peter POTM Winner - February 2017 Gold Member
    961
    b e l g i u m
    RB7 #166
    yeah, i knew about the group buy on the german clio forum. i sometimes have a peek over there. i even bought some brake pads in the forum shop, a couple of years back. :smile:
    you're not satisfied with the wavetrac?
  6. Louis
    Louis Paid Member
    3
    Clio 200 Cup
    wwwwoooowwww what a car :smiley:
  7. André R.
    André R. POTM Winner - September 2017
    50
    Clio R27r #2054
    Your clio is lovely, my favourite black clio <3
  8. rupe30
    rupe30 Paid Member
    142
    Stratford-upon-Avon
    Albi Blue RS197
    Awesome car! Can I gave a go?! How did the crash happen with the 200?
  9. J90RDN
    J90RDN Paid Member
    365
    Leicestershire
    Clio 197 - Track
    Which KW coilovers are you running? That car was very composed on track. Good drive :thumb:
  10. R11HOY
    R11HOY Paid Member
    159
    Conlig County Down Northern Ireland
    Renaultsport Clio 197 (2008)
    WOW....absolutely gobsmacked that has been some labour of love and the video link.......well what can you say, great car, great work, great viewing. I wish you all the very best..keep it up.
    :uk::kilt:
  11. steqpenwolf
    31
    Nordschleife
    Clio 3 RS
    No, I have no interest at all, as opposed to here in Germany is not so common.
    KW Clubsport :smile:
    Sure, I do not know since I have no memories of the accident, the SD card was apparently stolen by someone from the camera. The accident happened after a long closing and I was one of the first on the track I think the tires were just too cold at the rear!
    you can not say Dissatisfied ...but I think for the Nordschleife is a lamellar diff the better choice
    peter likes this.
  12. Slowride
    17
    Clio RS 197
    So wavetrac has no pre load? I thougt that torsen diffs work fine. What's your experience from oem To waverrac? And where are you looking for?
  13. tombate911
    tombate911 Paid Member
    667
    2010 Clio RS200
    Great looking car. Good to see everything done properly!
  14. peter
    961
    b e l g i u m
    RB7 #166
    @steqpenwolf ...
    yup. like to know as well. :smile:
  15. steqpenwolf
    31
    Nordschleife
    Clio 3 RS
    hey! The Wavetrack is not bad. However, it should work much better on small curves tracks like Zandvoort than on the nordschleife. In order for the lock to work properly you have to give more or less always full throttle which is not so good on the nordschleife as the range is very narrow.
    Im looking for a drexler dif
    Slowride likes this.
  16. Marsch
    Marsch
    407
    Berlin, Germany
    Stealth Grey RS 200
    Hi Thommi, just found this video with your blackbird (@1:23).
    I see the Cup spoiler is on again and there's a second seat fitted. Are you going to take me around next season?:tongueout:
  17. steqpenwolf
    31
    Nordschleife
    Clio 3 RS
    fter the missing compression on the third cylinder but then no longer out of my head, I have two replacement engines attached and one of them built last week.
    The engine is an 832. I have the toothed belt, WApu, spark plugs and the piston bearings and the thermostat exchanged. Otherwise, I have blasted all aluminum parts and now everything looks clean and new again.
    In addition, I removed the old fiery heat protection on the front wall and built itself from 0.8er aluminum.
    for the heat plate I first made a paper stencil
    At the end, protect the whole fabric from heat with a fabric tape.
    The connecting rod bearings were then replaced. as well as new rod bolts vw ARP. The Pleullager were by the way for about 90.000km not at all worn. one could save oneself.
    This image shows the most worn-out bearing
    After that I started from boredom the suction bridge, etc. to sandblasting.
    Reassemble and screw securely
    before:
    after:
    A new radiator from Valeo as well as a new expansion tank for the cooling water were installed.
    In addition, I had left something of the band which I still glued to the airbox, but is not yet finished
    Chris and Marsch like this.
  18. Pav
    Pav Moderator
    Manchester
    albi blue 197 with boost
  19. Chris
    Chris Bad cop Administrator
    Brilliant effort!
    Was the inlet manifold finish just purely from sandblast or did you paint it or anything?
  20. trackspec197
    trackspec197 Paid Member
    655
    Worcester
    Clio 197 BMW 320 M Sport
    Did you use my old motor Thomas? Mine had a ported inlet manifold which made a big difference to power delivery.
  • Share This Page
