Stud Kits
Discussion in 'Wheels and Tyres' started by petercronin, Apr 27, 2017.
  1. petercronin
    petercronin Paid Member
    150
    North East England
    LY FF Clio 200 with Cup Pack
    I've been asking around and having a few conversations on Facebook about stud kits. I was debating between two,
    This:
    http://www.elite-d.co.uk/race-wheel-stud-conversion-kit-14-x-1-5-renault/
    Or this:
    http://www.pure-motorsport.co.uk/cl...-m14-stud-conversion-kit-with-steel-nuts.html
    My concern was why is the elite on almost half the price of the pms but it seems people run them without issues. So I was almost about to buy them and then somebody said that they had problems fitting wheels once they're on as the lip on the stud doesn't allow the week to sit flush on the hub. This is standard wheels we're talking about the cup racer wheels have a countersunk hole to allow them to fit.
    Has anybody experienced this with any stud kits before? Also if anybody has any other comments/suggestions I'd be happy to hear them.
  2. PAUL JA
    PAUL JA Paid Member
    393
    Company shed
    I'd say you wont go far wrong with the studs from elite
    Bare in mind that if you fit the same length studs front and rear that you will have more thread through the nut at the rear than the front (by about 7mm - the thickness of the front brake disc bell)
    We use 90mm studs at the front and 82mm studs at the rear, these allow up to 20mm spacers with standard speedlines
    Us a high temperature locitite when installing
    These make wheel changes a doddle
    petercronin and LiamRS197 like this.
  3. petercronin
    150
    North East England
    Thanks for the reply, so I take it you've had no issues with the wheel not making contact with the hub using the standard speedline wheels?
  4. PAUL JA
    PAUL JA Paid Member
    393
    Company shed
    No issues, we are using hubcentric slip on spacers but I cant see that would make any difference
  5. petercronin
    150
    North East England
    Maybe the spacers have a slightly larger hole that fits over the lip on the studs. I might just order some and see where I want to go from there, either get spacers or countersink the back of the wheel bolt holes slightly.
  6. PAUL JA
    PAUL JA Paid Member
    393
    Company shed
    I'll check a stud in a wheel tomorrow
    The bulge on the stud is only 15mm
    I'm sure it'll be fine
  7. petercronin
    150
    North East England
    Thank you very much, you're a star.
  8. TB Rich
    TB Rich Paid Member
    Bournemouth
    Clio 200
    Hi Paul,
    If you were buying for no spacers, would you opt for 75mm front / 68mm rear then?
    I've no plans to use spacers and I don't really want studs that poke out far.
  9. PAUL JA
    PAUL JA Paid Member
    393
    Company shed
    Rich
    If they are closest to 90 / 82 less the 20mm spacer then they should be fine
    Paul
  10. PAUL JA
    PAUL JA Paid Member
    393
    Company shed
    The bulge in the stud will not pass through the wheel hole. A small countersink in the back of the wheel should sort it or sand a little from the bulge or run a shim spacer.
  11. petercronin
    150
    North East England
    Alright then, thank you for checking that. I'll have to have a think about what to do.
  12. TB Rich
    TB Rich Paid Member
    Bournemouth
    Clio 200
    Cheers - though from what the above posts say above I don't think they are going to work on the rear without spacers :\
  13. tcw
    tcw Paid Member
    79
    Colchester
    Clio 197
    I bought the Elite D kit - I got 90 and 82mm. I just did a trial fit, there will indeed need to be a countersink put in the back of the wheels (only the rears) for those not running spacers. I bought them so I can run silverstones on track, and standard wheels + 18mm spacer on the road.
  14. petercronin
    150
    North East England
    Good info thanks for that. I take it the lip on the front stud ends up covered by the brake disc bell and therefore doesn't interfere with the wheel?
  15. tcw
    tcw Paid Member
    79
    Colchester
    Clio 197
    Yeah exactly - on the front it appears front, though the rears will have the issue due to the lip without spacer. I'm planning on countersinking all the wheels I have - I'd not like to be stuck in an emergency :smile:
  16. petercronin
    150
    North East England
    I'm starting to think I might go down this route too rather than buy spacers. Are you planning on getting a proper countersink tool or just using a big drill bit? I haven't bought any studs yet but looking at the pictures I'm guessing the lip is around 2mm larger than the stud, so 16mm diameter - ish??
  17. Plummer
    Plummer Paid Member
    Does the TPI stud kit have this issue?
  18. Plummer
    Plummer Paid Member
    Does the issue only apply to the Elite kit?
    I've bought the TPI kit and wondering if I'm gonna have the same issue when I come to get them fitted.
  19. PAUL JA
    PAUL JA Paid Member
    393
    Company shed
    Don't know is the honest answer
    Best whip a wheel off and check, it'll only be a problem at the rear.
  • Share This Page
