RSPez Storm Grey 200
Discussion in 'Projects/Progress Threads' started by RSPez, Nov 19, 2016.
  1. LOCKE
    LOCKE Paid Member
    2,419
    Glasgow
    Car:
    RB 182 Cup/LY 197 R27
    Well that sounded like a right pain in the ....! Hope that's the last of your issues.
    RSPez likes this.
  2. RSPez
    RSPez Gold Member
    222
    Shrewsbury
    Car:
    Storm grey Clio 200.
    No only since November, but at least I'm learning about it I guess.
    Yeah I hope so too. I would like to actually do some of my own mods but untill its square I keep telling myself no.
    Dose anyone no about the lower rear engine mount, I no you can get an insert the large end but can you get a cotton reel polybush for the small side?
    Pez
  3. Daverb
    Daverb Paid Member
    351
    Fife, Scotland
    Car:
    Clio 197
    Or replace it with a Vibratechics mount.
    I thought you could get to the pump from the rear seats?
  4. RSPez
    RSPez Gold Member
    222
    Shrewsbury
    Car:
    This is true but would that cause a lot of vibration with the vibratecnics mount?
    No you can't get it though the "service" hatch under the seat as its all off set and to small.
    Pez
  5. Big Ben
    4,685
    Herts
    Car:
    197
    I've got an unused Powerflex lower engine mount @RSPez if you need one bud?
  6. RSPez
    RSPez Gold Member
    222
    Shrewsbury
    Car:
    I'm okay at the moment thank you.
    I'm going to see what other people say about the Cotten reel bush or maybe get a vibra mount.
    Pez
  7. VolumeX
    VolumeX
    651
    Car:
    Clio mk3 197 & 200 20th
    Quick Question, I see you have Sat Nav, are you planning a sound upgrade?
  8. RSPez
    RSPez Gold Member
    222
    Shrewsbury
    Car:
    A sound upgrade as in speaker upgrade or head unit?
    I'm not looking to get an Aftermarket head unit if that what you mean.
    Pez
  9. VolumeX
    VolumeX
    651
    Car:
    So no HU upgrade then. Cool Cool.
    RSPez likes this.
  10. RSPez
    RSPez Gold Member
    222
    Shrewsbury
    Car:
    So little update.
    Cars booked in for full belts and full service at RSTuning on the 24th.
    Iv found out the fault/code that's causing the engine light.
    It's:
    P2075
    Intake manifold tuning (IMT) Valve position sensor switch circuit bank 1a.
    Any ideas what this could be?
    Something to do with the TB?
    Pez
  11. Ade T
    Ade T Paid Member
    202
    Had that code with diesels before and it was the swirl flaps. Obviously these don't have swirl flaps but could well be the throttle body. Perhaps try giving it a clean out.
  12. RSPez
    RSPez Gold Member
    222
    Shrewsbury
    Car:
    Cheers.
    Yeah having a look on the internet it may well be that. I will have a look at it tomorrow.
  13. Chris
    Chris Bad cop Administrator
    10,548
    Needham Market
    Car:
    LY 200t
    Quite easy to do. There's a guide in the how to if you should need it!
  14. RSPez
    RSPez Gold Member
    222
    Shrewsbury
    Car:
    Thanks chris will take a look now.
  15. Pav
    Pav Moderator
    10,679
    Manchester
    Car:
    albi blue 197 with boost
    Yeah 10mins job..hope you get it sorted...
  16. RSPez
    RSPez Gold Member
    222
    Shrewsbury
    Car:
    Little update.
    Iv fitted a lower powerflex mount this past couple of weeks.
    Seems to have helped with the gear change especially at higher RPM.
    But still feels a bit *Jerky* at lower rpm in first and second.
    I think it's the cotton reel bush at the front of the mount that the problem is.
    Today Iv taken the Throttle body and PCV valve off with help of the guide on the forum for the pcv.
    Throttle body wasn't overly dirty but Iv cleaned it anyway.
    Before
    After
    The pcv valve was pretty mucky Iv give that a good clean as well as the pipe.
    The fitting where the pipe go's on to the engine side was full of crap so got the best I can out.
    Been for a drive and it seems a lot smoother.
    Before
    After
    I thought maybe cleaning these would make the idle a bit better and not as rough but it hasn't made much difference, I will reset the engine light again now I have cleaned these and see if it stays off.
    If not I fear I will need a new Throttle body.
    Pez
    Dystant likes this.
  17. ///M
    ///M Gold Member
    4,716
    Car:
    R27, ///M CS, Exige V6
    Excellent work mate. Like having a good poo getting rid of that lot!
    Seeing your recent posts has really made me think about getting ours sorted out. Good photos. Glad to hear there has been at least some benefits.
    RSPez likes this.
  18. RSPez
    RSPez Gold Member
    222
    Shrewsbury
    Car:
    Thanks.
    Yeah it is such an easy job to do as well. It's very rewarding knowing that it's going back together again clean.
    I will check up on it in a month see if there is much muck in there.
    I no that it's been discussed a lot but if there throttle body is knocked is it worth getting a 64mm one?
    Pez
  19. ///M
    ///M Gold Member
    4,716
    Car:
  20. sevenfourate
    sevenfourate Devotee of OCD Paid Member
    8,376
    Lowestoft, England.
    Car:
    Racing Blue RS-200
  • Share This Page
