1 test Tom to see if it's the release bearing on it's way.
1st gear clutch hard to the floor, engine running, stab the throttle take it up to 7k and lift off throttle. Handbrake needs to be off and on level ground. Any movement in the car i.e a slight jerk at peak revs the release bearing is worn and will need changing soon probably a good idea to uprate the clutch if u intend on doing more track days
be prepared for a massive argument on the wear and tear clause of the warranty. they will try and say that it is wear and tear of the clutch and then try and charge you £640 + for an inspection lol the "197's/ 200's were nutorious for cracked housings that leak clutch fluid" and they will go on to say if this is the case then it will be a warranty repair but if not you have to pay the top line labour costs.
all I can suggest is getting an independant garage to replace your clutch and release bearing to an uprated 1 and you will get a long time out of it. Helix make clutches to order and a paddle 1 will aid your track day addiction no end. I think mine was £320 + £120 labour to fit it.
If it were 3 years old with 60k on the clocks it would be reasonable, I don't abuse the clutch and have been as careful with it as possible but it's booked in now for a list of issues that I have including the gearbox being a bit crap and the bolsters wearing again.
funny this well kinda depressing when i change gear its like 3 small judders up and down the gears when im depressing it in to gear,is mine needing replaced then ???? 28 k miles nearly 4 year old
its hard to say mate, do the small test and it will tell you. if its only slight its on its way out but will last anohter 10k ish if it was anything like mine where it even moved with the handbrake on its immenent.
Well we'll see when it goes in, I could afford to get it done myself using uprated parts but that'd go against my commitment to no modify it mechanically
yeah i know what you meen but how long do you intend to keep it and keep tracking it tom? sometimes even performance "road" parts cant keep up with what i suppose is clased as "motorsport" and the last thing you want is your clutch to fail on a track day.
The warranty doesn't cover reasonable wear and tear. It's down to you and the garage to discuss if you've had reasonable wear and tear so definitely don't tell them its been on track and maybe tell them you just do motorway commuting or something like that.
