Replacing Recaro's from 197 with Standard seats from a 200?
Does anyone know if Standard seats from a 200 will fit straight into a 197 in place of the factory-fitted Recaro's - without changing subframes, runners etc?
And what about the seat belt resistor/warning beeper?
They should fit without any problems but you may need to reactivate the anti-submarining airbags
Yea I've done it with a leather interior from a 200 into a 197 but remember this a Clio 200 has only 2 seats in the back and a 197 has three seat belts come MOT time, so the 197 has three head rests across the back. The extra airbag on the base of the standard seat might need activated but with it deactivated there will not be a airbag light problem. If you have the radio amplifier under the drivers seat check the 200 seat does not have a straight bar that unlocks the slide rails when you tip and move the seat forward it hits the back of the under seat box.
