Rear Speakers in 08 197????????
Liam Gunby
Was just wondering is my 08 plate 197 supposed to have rear speakers?
I removed the speaker grills and there's nothing there. But on the drivers side i found a speaker connection cable behind the trim......
So im confused.
Never thought anything off it before as not all small 3 door cars have rear speakers. But the found wire has me thinking.
anyone shed any light on this?
Thank you.
6 speakers was an optional upgrade, all you got as standard is fronts and tweets. Pop down to any breakers and you'll get a pair of rear speakers for a fiver...
Haha I had a similar issue with my old twingo GT. pulled the trim away to find no speakers just a bunch of cables.
If ya after an upgrade get some aftermarket ones or ad above just find some from a breakers / scrap yard
Yes i got the same surprise in mine just the cables and some dust lol. The size i believe you need are 13cm top of my head and should only have 2 tabs on them, which any normal 13cm speaker will have 4 tabs for fitting, either chop 2 off or bend them the option is yours unless you get renault specific speakers which will fit perfectly but the choice and cost are a bit up and down. I personally upgraded to pioneer and gently bent the tabs to fit on all four speakers. Not the most professional job in the world but i dont think the worst either :blush:
Reactions: Liam Gunby
