rear camber shims ??
Westallc
evening all im currently building a track car from a 197 f1 clio and would like to run a 2 degree rear camber shim any idea where to buy from
many thanks
clive
Renault Sport has it too, caster and camber shims. Your ride hight has a big influence on your camber and caster. Keep that in mind.
1° wheel alignment shim 77 11 160 169
30' wheel alignment shim 77 11 160 170
20' wheel alignment shim 20' 77 11 160 171
10' wheel alignment shim 10' 77 11 160 172
1° Camber alignment shim 77 11 160 173
30' Camber alignment shim 77 11 160 174
20' Camber alignment shim 20' 77 11 160 175
10' Camber alignment shim 10' 77 11 160 176
