ex Nimbus r27r #2054
hi mates!!
my r27r #2054... 1170kg with 20lt fuel
•Coilover ORAP replica cup 90N/mm front 90N/mm rear rebound adjustable
•Engine cradle modded like clio cup
•Front arms suspension on uniball
•Adjustable TopMount MC Motortecnica
•Front 2.2° camber, 0 toe; Rear 2.2° camber, 30' open toe
•312 mm composit disc 6,3kg each
•Ferodo DS3000 front pads
•Goodridge brake line
•Motul rfb 600 brake fluid
•Motul 300v 15w50 / 5w40 / 10w40
•Bardahl 75w90 Gear Oil
•Inlet manifold worked
•Airbox Clio Cup/Clio v6
•Air filter Green
•Head engine worked
•Balanced crankshaft Clio R3 250
•Clio R3 230 cams
•Clio R3 250 pistons
•Clio R3 250 conrods bolts
•Saenz steel conrods H
•Bottom upgrade engine mount
•Cable throttle Clio Cup/Clio R3
•Steel flywheel
•Reinforced pressure plat
•Quaife differential
•14/69 Couple
•Engine balancing
•Aros exhaust, decat, r3 250 exhaust manifold
•GetData Ecu with 2 map (1 with wideband autocorrection)
•Zeitronix Zt-2 Wideband
•Engine room mapped
•Air Conditioning removed
•Radiator liquid moved, in stainless steel
•OZ Ultraleggera 17” 8j matt black
•Xilema wheels rods
•Dunlop direzza 03g
•Oil temperature gauge AEM
•Oil pressure gauge AEM
•Steering Wheel Renault Sport
i think it's all...
Re: My R27 Nimbus!! (...after summer)
great pics as ever simone... 8-)
Amazing pics!
How much have you dropped your car by?
What size are your spacers?
carlo_sg said:
Amazing pics!
not spacer carlo, ultraleggera 17" are 8j and et55 +19mm
...and 7.9kg each..
simoxmino said:
carlo_sg said:
Amazing pics!
...and 7.9kg each..
How much did the standard wheels weigh?
Your car sits very low (I presume after-market coilovers), how much lower is it?
carlo_sg said:
simoxmino said:
[quote="carlo_sg":3ssfx27v]Amazing pics!
...and 7.9kg each..
Your car sits very low (I presume after-market coilovers), how much lower is it?[/quote:3ssfx27v]
standard wheels are 10kg..
i've KW var1 coilover, around 1000€, at rear i'm all down, in front i've 10cm i think...
Fantastic, your car looks so mean like its going to rip your face off, absolutely love it.
Can I ask a favour, do you mind if I use your 3rd picture down as my desktop background? If so do you have a bigger picture 1280 by 1024?
Great photos there, almost looks like the cars been painted in chrome with some of the reflections coming off it!
The wheels suit the car too, not many that do imo apart from the stock rims, but those work, and the black badges are a nice touch too, I've been thinking about doing those too so now think I will :smiley:
here the background, is 1280x1024.. there is a little cut because is not in proportion.. :wink: :wink:
http://i29.tinypic.com/do49bn.jpg
Fantastic, that picture makes such a good desktop background :smiley: 8-)
Simone, I have to admit I am jealous. You have a 1d Mk2, an R27 with my personal favourite mods, and live in an area I would dearly love to. Living in the UK sucks, I wanna move somewhere that has real seasons! Hot summers and COLD winters.
