I am definitely changing my front pads and discs, as I suspect the discs are warped and the pads don’t have much wear left. I am looking for some advice on what to do next.
A. Replace like for like discs and perhaps uprate pads – can you recommend a good pad for reasonable cash? I’ll probably go to TwingoGeeko or Brembo website for prices on the discs.
B. Replace discs with uprated cross drilled and/or grooved numbers. I am not looking at any 2-piece items as I don’t think road use merits them, but any recommended discs would be appreciated. Also, are the benefits noticeable uprating the discs?
I can’t fault the standard set-up aside from the usual braking from cold in very cold conditions, which can happen regardless what brakes you have IMO.
Also, is it worthwhile to uprate brake fuilds?
And finally!! Should I buy new pins for the callipers when replacing?
Thoughts suggestions please!!!
8)
8)
