Hi all,
I put a post up a while back about the squeaking I was expirencing. Posted a video and the noise was coming from the cambelt side.
It was said it could be the depresser pulley.
I have been told I can use a multimeter to test.
This is what I have been told...
unplug the connector from the top of the solenoid and put the probes on each pin. You should see a resistance value of 9.5-10.75 kOhms... if not, replace!
Is it just a case of doing this or do I need to unplug the battery or anything. Not that great with these type of things...
Matt
Matt
