well the update on the filter cleaning is as follows..emailed ITG to make sure the oil was ok,as it seemed not right.this is there response.
There isn’t a problem with you cleaning the filter but it sounds like you
have used the wrong oil, and too much of it.
The JDR-1 which you have (it has a white marker dye) is intended mainly for
race use - it is a very light oil that is easy to clean off after every
race.
The oil you should have used is our JDR-2 which is a lot stickier and less
prone to run off the filter when over oiled.
All you need to do is wash the filter out again (petrol is good) and then
re-oil with the JDR-2 (being careful not to over oil the filter).
Best regards
Andy Jackson
Technical Support Advisor
Induction Technology Group Ltd
www.itgairfilters.com so if you clean your filters make sure you all get the JDR2 OIL.
