How to resize pics ?????
get the url of the DIRECT image and add [IMG ] [/IMG ] tags at either side of it.
(without the space after /img)
or quote this post, and see what i've done with the image below
Just paste the IMG block into the post directly. Only use the toolbar img icon if you have a url that ends in .jpg and not [/IMG]
Don't they need to be hosted somewere like photobucket/flicker first?
You can't put the
I use imageshack. If you're not tech savy, it gives you a forum code anyway. Just copy and paste :smile:
NUMPTY!!!
The two bits in [] at each end...replace the letters url with IMG (but do not delete the / in the second []
So: [.IMG]http://farm9.staticflickr.com/8147/6975460496_f36090063a_b.jpg[/..IMG]
Remove the dots :wink:
anyone looking to do this should just go to tinypic, you can select what size to upload you image as.
Simples
How to?
Been on the forum for a while but just became a paid member
How to i put pictures on from attachments where there small
to the actual big pictures straight away if that makes sense?
