How much fluid?
As above, did mine today and used nearly 1lt, bought 2 so at least I have one spare now.
I used ATE Super Blue Racing, a few people on here recommended it plus as it's blue it makes it easier to see when it's run through the system.
done a full fluid change a month or so ago and flushed through at least 300ml per side/brake = 1.2ltrs
dont forget the front calipers have 2 bleed points and have a bit more fluid than standard single piston calipers
Had mine done at a renault specialist and they used less than 1 litre to flush through, probably buy 2 litres though if you're not an expert at bleeding brakes!
The Renault garage I'm taking the car to said if I have the parts they'll fit them whilst doing the service win win :smile:
