Horn issue - need it for MOT! (check this first)
Heppy997
Right lads, my 197 failed its MOT on a few things (7 to be exact), I've managed to fix them all bar one: the horn. Normally I wouldn't care (its just one of those Renault things) but I need it through the MOT. The horn itself is fine as I have tested it off the car, but there is no power to it. The switch on the steering wheel seems fine, contacts ok and immediate wiring is ok. Fuse is intact. Checked the clock spring cable in the squib, seems fine. Only thing i haven't checked is if there is 12v at the fuse...
Does anyone have any ideas? Is there a relay for it?
At this point I'm thinking of just wiring up my own switch on the dash and running a new wire to it just to pass the MOT as its driving me insane. Especially as i have already spent weeks sorting all the other problems (x2 ball joints, shocks, brake rebuild etc etc etc.).
The buttons for the trip computer also do not work and I have swapped the stalk all to no avail (couldn't be that simple could it:sleeping:), not sure if this could be related?
Yes. Remove the stalk and double check the prongs aren't bent back. I spent ages checking power to fuse, power to horn, earths etc and it was a 2 minute job. The prongs get bent and breaks the contact if they have been put back incorrectly. Hope that helps
Reactions: Big Ben
Yes mate. Remove the steering column surround and there are 1 or 2 torques screws holding the stalk in place. Unclip the connector, in screw it and there are prongs on the end of th stalk that mesh against contacts in the column. Sometimes these prongs bend the wrong way when they have been previously removed and put back wrong. They can bend and avoid contact.
Reactions: skny
Just did the same with mine, genius! I now have a horn again. Sadly I’ve already ordered a new squib [emoji17]
Sent from my iPhone using Tapatalk Pro
Good idea, think a few people have this issue. Just be careful with the contacts bending them back etc, as one of mine has just snapped off...:expressionless:
thanks trackspec197!!! this has just help me fix the same issue on mine :smile: guess I must have put the wipers stalk a bit carelessly when replacing the indicators stalk that stopped working a few months ago, only noticed the horn is not working about a week ago LOL but now after 2,5 minutes of a job its fixed ! thanks a lot !!!
