Hi from Oz
Another small update...
Fitted the RS Synthetic rubber mats, had the same type mats in my JCW & loved them. Fantastic quality & wear much better than the oem carpet ones.
[/URL][/IMG]
Impressions?
Wow what an improvement.
If you don't mind more NVH the 'Vibra Tech Torque Link' is a must have, better throttle response, shift feel, launch quality & drivability.
For a few dollars & 30 minutes fitting time the result is honestly amazing.
Fitted a rear tow strap, requires making an adaptor as per front strap, however there is a little more work involved as the factory tow point is hidden behind the bumper, so you must remove both the diffuser & bumper to gain access.
Fortunately the rear tow point is located directly in line with where the diffuser meets the bumper so no holes need be made, just a little internal trimming which can't be seen once reassembled.
Another benefit of this location is that the strap can be used to pull the car at a variety of angles without damaging the bumper/diffuser.
[/URL][/IMG]
Fitted interior door handles as per Masa. Look oem & fall to hand perfectly.
[/URL][/IMG]
Removed rear seat & isofix bar & carpeted vacant area where seat was (saved about 15kg).
[/URL][/IMG]
Fitted new black leather with yellow stitching handbrake & gearstick gaiters.
Also dyed steering wheel stitching in yellow to match.
[/URL][/IMG]
[/URL][/IMG]
Fitted charcoal 18" Meg R26 Cup rims with 225/40/18 KU39 Khumo's.
[/URL][/IMG]
[/URL][/IMG]
Painted my Speedline track rims in Fluro plasti-dip & fitted new Kuhmo ku36 semis'...
[/URL][/IMG]
[/URL][/IMG]
Latest pics complete with new track sponsorship on board...
[/URL][/IMG]
[/URL][/IMG]
Managed to locate an 'as new' complete leather interior from an A&D 200 (recaros, rear seat & doorcards).
Much much nicer place to be now, plus the factory spec tissue paper on my drivers seat bolster was starting to wear.
Painted harness slots in Recaros & fitted & painted interior grab handles to door cards.
[/URL][/IMG]
[/URL][/IMG]
[/URL][/IMG]
