Glove box
Can someone do a DIY how to remove the glove box?
Could be useful in the future.
No pictures but,
1) Use a flat headed screwdriver with a cloth covering the tip, put it under the right hand side of the silver trim above the glovebox and prise it off, should come off quite easily. Once you have the first popper off just use your hands to pull the rest off.
2) Under the silver trim you will see 3 size T15 torx screws, remove them.
3) Open the passenger side door and remove the panel on the side of the glovebox with the airbag sticker on it. Careful as it is hinged under the door seal rubber.
4) Once removed you will see another torx screw, remove that.
5) Open the glovebox and look up inside it and you will see another torx screw, remove that.
6) Everything is free and it's just a case of pulling the glovebox out towards you.
Job done !
Refitting is the reversal of removal. If you break something following this guide it isn't my fault :-p
Dealer switched my lid for free the other week, its perfect now. They said most of the time the clips break when removing the lid so you must have had some careful hands lol :tongueout:
