Fuel lines
Discussion in 'Engine, Gearbox, Exhaust and Air Intake' started by R411YKA, Jan 13, 2018.
  1. R411YKA
    R411YKA
    29
    Car:
    197 rally
    hi guys
    Does anyone have a drawing of fuel line layout?
    Where is the pressure valve?
    Just putting braided lines back on and cant remember which is flow return etc
  2. TB Rich
    TB Rich
    2,049
    Bournemouth
    Car:
    Clio 200
    Standard fuel line setup is a returnless, so only single line from the fuel pump sender unit. The pressure reg is located at the bottom of that unit, and bleeds excess fuel directly back in the tank so there is no return line.
  3. R411YKA
    R411YKA
    29
    Car:
    197 rally
    I thought had return to tank from back of engine?
    Is pressure reg on bottom of tank on n/s?
    If you could give me a call 07801 749623 as not sure how they run
    Or ill call you
    Tganks
    Andy
  4. R411YKA
    R411YKA
    29
    Car:
    197 rally
    On driver side in engine bay what does fuel solenoid do?
  5. TB Rich
    TB Rich
    2,049
    Bournemouth
    Car:
    Clio 200
    Fuel solenoid.... can't say I've come across one yet on these, but usually in a road car it's for roll over protection to shut off the fuel supply.
    Upgrading the fuel system in mine is an imminently pending job, so for now I haven't had it all apart from tank to rail.
    However @Stephenvenning has replaced his lines (converted to a return setup) - so is probably the best guy to ask here.
  6. R411YKA
    R411YKA
    29
    Car:
    197 rally
    Thanks, Ive PMd him.
    I'm pulling my hair out.
    On the back of inlet manifold there are two pipes what are these for? that's what I thought was fuel return and am getting confused lol
  7. TB Rich
    TB Rich
    2,049
    Bournemouth
    Car:
    Clio 200
    Back of the inlet, yeah they ain't fuel! :smile: 1 is the brake booster & the other carbon canister.
  • Share This Page
