TB Rich
Good stuff mate. Next time you are in the garage ask some info about those 2 pot calipers which are on that rear axle!
That's a Maxi rear beam with the optional AP caliper setup
Nice one rich! Now, where can we get these babies from then?
R Sport I guess, if you just want the calipers though then they are (7711162466) & (7711162467). Would advise the bracket to fix to the rear beam and provide a radial mount for the calipers too (2x 7711162470). Also rear discs as they are 274x11 (2x 7711160603).
From the looks of the diagrams (Cup Racer, Access, Maxi) the bracket will fit the standard rear beam fine as the shims used across all 3 are the same - this means the bolt spacing on the bracket will line up and mount fine.
The issue maybe needing the stub axles (7711160614 & 7711160615), but theres so many shared items across all 3 I would be seriously tempted to order 1 bracket, 1 caliper and 1 disc. It wouldn't take you more than a couple of hours to try a side and other than needing to fab a couple of new brake hoses either side I think it'll work (probably!!!).
Have you got the Maxi and Cup Racer parts lists?
ive never seen it look like that though? is it an upgraded version or a race version? ive only ever seen the black rubber type
S | Clio 197 in Racing Blue FSH 65k £5,500 | Clios For Sale | 1 | |
Racing Blue Clio towards Newbury. | Spotted | 0 | ||
Mike's racing blue 197 | Projects/Progress Threads | 88 | ||
BAF Motorsport K-brace vs Ultra Racing | Interior and Audio | 6 | ||
new member - working on a virtual model of the Clio for sim racing | New Members | 10 |
