Brunoandrade98
			Hi all,
As the title states, I have a few issues with my 197. Some of them might be related with other problems listed.
I'm wondering if anyone could share some input on them:
Low MPG
My car has quite bad MPG. I understand these cars aren't a cheap runaround, and that I shouldn't expect really good MPG on a hot hatch, however, it has gone as low as 18MPG, which I think it's quite bad.
So far, I have checked my spark plugs, and they look...used. They are NGK, and they're not in bad shape, but used. The oil and filters have been replaced in February, prior to me buying the car. It may be related with the problem below.
Exhaust leak?
It may be my mind playing tricks on me, but I can hear a bit of exhaust underneath the car. I just put the car on ramps, and had someone rev it while I was underneath, looking for any signs of smoke, which I couldn't see any. I could, however, smell exhaust gases from where the manifold is, which I'm not sure how normal it is. One other thing, is that there's a bit of a vibration when revving, and a bit more sound coming from the front. Could this be related with the exhaust? I understand that, if there was an exhaust leak, it could affect the O2 sensors, and I could be running richer.
Is there any easy way to check for this?
Car feels unresponsive
This is the "fastest" car I've owned. Before this one, I was driving a Mini Cooper S R56, with 175HP. Now, the Mini had a lot of issues, but it felt quicker than the 197. It also had better MPG, at about 25-28, with a similar driving style. Not sure if it's because it's a turbo, and has more torque, but it did feel quicker. I wonder if there is an issue with my engine that could be affecting the engine in a negative way, with a loss of power, and lower MPG?
P0313 code on OBD Reader
I plugged an OBD Reader and ran a diagnostic. It came back with a P0313 code, which stands for "Misfire Detected with Low Fuel". The car was on low fuel, but I couldn't tell if there really was a misfire, as the engine sounds okay. I cleared the code, filled her up, and been driving her for a while, to see if the code comes back. It hasn't.
Noise going over bumps
When I bought the car, one of the tyres was quite deflated, so, I powered on my compressor and filled all 4 corners to the correct pressure, as stated in the handbook. All four corners were rather deflated, with one one of the rear tyres being at 8PSI! After filling them up, I could hear a noise when driving in general, but especially when going over bumps. My guess is that because the tyres were quite deflated, the ride was that much smoother that I couldn't notice the noise.
I have checked all four wheels for play, and they were all solid, so, it looks like my suspension is okay. I thought it could be the exhaust that was loose, which could explain an exhaust leak, but I couldn't see any signs of that, either.
Apologies for the massive wall of text, but I'd really appreciate some input on this.
Thanks in advance
Low MPG
Exhaust leak?
Thanks in advance
