Do I have an LSD?
Discussion in 'Engine, Gearbox, Exhaust and Air Intake' started by m.a.c, Aug 9, 2018 at 10:51 PM.
  1. m.a.c
    m.a.c Gold Member
    92
    Car:
    Clio 200 Cup
    When the front wheels are off the ground and spin the n/s clockwise and o/s spins anticlockwise does this 100% confirm I have an LSD?
    Matt
  2. Yiannis197
    Yiannis197 Paid Member
    3,633
    London
    Car:
    Clio R27
    Hi Matt, that 100% confirms that you don't have an LSD. If you had, both wheels would be turning towards the same direction.
  3. m.a.c
    m.a.c Gold Member
    92
    Car:
    Clio 200 Cup
    Okay, I meant the direction of the wheel when looking at them from the side.
    Both wheels turn in the same direction when spinning one wheel.
    What’s the difference with an LSD and gripper?
  4. petercronin
    petercronin Paid Member
    298
    North East England
    Car:
    LY FF Clio 200 with Cup Pack
    A Gripper is just another type of LSD, it uses plates (a bit like clutches) to provide the locking action. Whereas other types we can have for the Clio (Quaife / Wavetrac) basically use gears.
  5. Dumdum
    Dumdum Gold Member
    410
    Car:
    Renault Clio RS200 CUP
    Even then it proves nothing, you might have a tight diff and it’s just turning the second motion shaft in the gearbox and the entire diff
  6. Dumdum
    Dumdum Gold Member
    410
    Car:
    Why do you think you have an lsd?
  7. m.a.c
    m.a.c Gold Member
    92
    Car:
    Clio 200 Cup
    When I bought the car I was told it did, but no proof!
    If I make the wheels spin on pull away both wheel will slip not all the power going to one of the wheels that has the least grip.
  8. Dumdum
    Dumdum Gold Member
    410
    Car:
  • Share This Page
