massivewangers
I have noticed a bit of a weird issue with my 197 (manual air con) - the dash vents don't seem to flow much air, even with the blower turned up to four.
The blower itself seems to be working fine and changes speed for each setting. The air con blows cold too (though might benefit from a recharge). It's just that, even with the system set to blow purely out of the vents, it just doesn't flow very much. And, if I switch the setting, none of the other outlets appear to flow a massive amount either.
One thing I have noticed is that there is some consistent air flow into the passenger footwell (on the right of the car in my case!), which suggests that something is amiss with the way the air is being directed.
Is this something anyone else has come across? It touched 39 degrees here yesterday, so I'd really like to fix it
