Conversion time
Discussion in 'FI' started by Pav, Oct 19, 2017.
  1. Mark_L
    Mark_L Paid Member
    168
    197 Cup
    Doesn't your pms have 2.25 or 2.5" out of the rear box? @matt555
  2. matt555
    matt555 Paid Member
    17
    M135i 197 Turbo
    Yeah something like that, 3” into single centre mounted back box with 2” ish tail pipes. Would need to measure them to be sure
  3. Mark_L
    Mark_L Paid Member
    168
    197 Cup
    I think I'm going to run the 3" into the t piece for the rear boxes and see how it goes. like we were talking about the other day.
  4. matt555
    matt555 Paid Member
    17
    M135i 197 Turbo
    I think that’ll be more than adequate. The volume of the two smaller pipes is greater than that of the single 3”
  5. Mark_L
    Mark_L Paid Member
    168
    197 Cup
    That's my opinion too.
  6. JamieRS200
    JamieRS200 Paid Member
    15
    Clio RS200
    Your logic sounds like it wouldn’t be an issue Mark, I may have to go down that route, I’m guessing pms don’t supply the centre section to the rear box on its own? Then again it’s probably unlikely that it will match straight up to my scorpion back box?
  7. Mark_L
    Mark_L Paid Member
    168
    197 Cup
    All systems are different. Looking at the specific scorpion system the second link before the axle pipe is basically a straight pipe. What you might consider is the scorpion 3" system can be bought on eBay for £833. Including the downpipe/decat. What's your scorpion worth s/hand? The difference may only be a few hundred or so. I know someone who managed to get it for £700. But I don't know the details.
    Here's another link.
    https://rover.ebay.com/rover/0/0/0?mpre=https://www.ebay.co.uk/ulk/itm/382301953508
  8. Pav
    Pav Moderator
    Manchester
    albi blue 197 with boost
    think everything was said and thanks for all your responses..
    i myself run a 3" link/down pipe to my 2.75" ktr system..630cc injectors,forge cooler,hard pipe kit.250 turbo and it made 282/300 on dyno..
    you will need a reducer if you want to run your standard exhaust..think it makes sense to upgrade to a 3" while you are at it...
    Mark_L likes this.
  9. Sean197
    Sean197 RIP Albi :( Moderator
    Fife, Scotland
    Albi 197T - RIP, MK7 Golf GTD Sports Wagon
    ktr clio system is 2.5" I think Pav.
  10. Pav
    Pav Moderator
    Manchester
    my is defo 2.75"..measured it when i was getting my stainless tips for it...
    Sean197 likes this.
  11. Big Ben
    Herts
    197
    I made 270/274 with Scorpion 3” downpipe linked to a scorpion 2.5” system.
    I’ve since bought a full scorpion 3” system and I’m now at 275/288.
    Hope that helps
    Pav likes this.
  12. VanHalsing
    VanHalsing
    3
    Germany
    Clio 3 RS, Nissan 200SX S14
    Hey guys,
    maybe someone can help me, works the R26 Ecu with an megane ph1 engine and a fitted loom in the clio197?
    Greetings from germany
    Patrick
  13. JamieRS200
    15
    Clio RS200
    I don’t think it’s possible to use the phase 1 loom? But someone else might be able to give your more info
  14. VanHalsing
    VanHalsing
    3
    Germany
    I want to use the clio loom and add the wires for map sensors etc. The question is, will a r26 ecu work with the ph1 engine? What about the ph1 ecu? Works it with the clio electrical system?
    Greetings Patrick
  15. Pav
    Pav Moderator
    Manchester
  • Share This Page
