Clio Red bull 2012 not starting
Discussion in 'Engine, Gearbox, Exhaust and Air Intake' started by KenClioRedbull, May 30, 2018.
  1. KenClioRedbull
    KenClioRedbull
    13
    Car:
    Clio 200 redbull
    Hi guys,
    Lets tell you tell what's going on climbed a kerb broke a rim busted 2 airbags Recaro side and curtain airbags stopped starting after that. Crash data cleared SRS module cleared airbags replaced. no more airbag light on dash :smile:.
    • 1 Fault code pending could not find any info on it DF020 FRONT INTERIOR AERIAL CIRUCUIT( what ever that means).
    • Immobiliser is normal light goes off.
    • battery perfect.
    Car cranks motor attempts to start but dose not.ESP/ESR deactivated pops up on dash only
    Things I have done
    • TDC sensor cleaned and changed with new one still nothing (was working fine before accident)
    • Fuel pump works only when direct 12 volt power is applied from a external source i.e battery.
    Things I know that are not working properly
    • Fuel pump PLUG is not giving any power at all ??????????
    Rest of the car is in good nick just bloody wont start. Cleared all codes stored in numerous ECU such as SRS and Main ECU.
    NO FAULTS except the one on top and I don't know what it is.
    How can I get power to that plug any ideas cheers.
  2. link
    link Gold Member
    339
    Hyrule
    Car:
    Clio 197 RB
    Which computers getting that fault code in? Can only find one reference to DF020...
  3. KenClioRedbull
    KenClioRedbull
    13
    Car:
    Clio 200 redbull
    This fault is in the uch but there is no fault code for asr esp strange.
  4. link
    link Gold Member
    339
    Hyrule
    Car:
    Clio 197 RB
    Ah, found it. Here you go mate...
  5. KenClioRedbull
    KenClioRedbull
    13
    Car:
    Clio 200 redbull
    that's sorted cheers thanks.
    But still no bloody spark or fuel... immobiliser or the uch is simply locked I dunno any idea fokes
  6. link
    link Gold Member
    339
    Hyrule
    Car:
    Clio 197 RB
    UCH are known to fail, given that it's cranking over it must be detecting the keycard? I guess you have two options, replace UCH or aerial...
    Bit strange if it was working prior to the crash, are you sure the airbag computer isn't locked still? Did you actually replace the SRS module?
  7. GazMav
    GazMav Paid Member
    11
    Car:
    197
    Do these not have a fuel cut off switch? I know some cars have a switch that triggers in an accident to stop power to fuel pump.
    Edit: nope doesn't look like there is on these, sorry
  8. Foxspeed
    15,474
    Car:
    ford mustang shadow gt v8
    was thinking the same on this one!
  9. tombate911
    tombate911 Paid Member
    889
    Car:
    2010 Clio RS200
    Only way we've managed to do it in the past is replace the airbag computer from a similar specced vehicle.
  10. KenClioRedbull
    KenClioRedbull
    13
    Car:
    Clio 200 redbull
    I’ve managed to get my hands on clip everything is showing as no faults uch ucp I can actually test the whole car with clip all ecu are communicating together no problems vin numbers all match. How come I can’t get fuel or spark. Airbag module was cleared with carprog and clip pics it up as no issues all good .
  11. link
    link Gold Member
    339
    Hyrule
    Car:
    Clio 197 RB
    If you've got CLiP then it sounds like all the multiplex network showed up green?
    We're all the computers also green? If they show in red then it means there's a fault...
    Did you check the SRS module is unlocked?
    As said before sounds like either UCH or SRS module is bricked, there's no such thing as coincidence in my experience.
  12. KenClioRedbull
    KenClioRedbull
    13
    Car:
    Clio 200 redbull
    Multiplex network is all green except for the UCH that’s red Fault Showing internal aerial fault the ESP asr light is not turning on any more. The SrS module is showing greeen???? No impact detected vin matches there.
    Do you recon the uch is cactus or srs is cactus. If so I have a demon Clio 197 I’m wrecking is it as simple as reprogramming the uch or nah.
  13. link
    link Gold Member
    339
    Hyrule
    Car:
    Clio 197 RB
    Some more info on that fault...
    Sounds immobiliser related, I'm guessing that fault won't reset via CLiP? Gimme a mo. and I'll find where that sensor is located on ViSU.
  14. KenClioRedbull
    KenClioRedbull
    13
    Car:
    Clio 200 redbull
    Sorry I meant DF020 fault comes up front interior aerial in the uch read yr previous attach you sent ages ago couldn’t find any problems there.
    Immobiliser would the car still crank?
    I ran the command via clip for aerial fault finding didn’t come up with no faults.
    I’m banging my head on the wall I can even test the fuel pump relay on clip Huns like a bee
    The only thing I can’t test is ignition
  15. KenClioRedbull
    KenClioRedbull
    13
    Car:
    Clio 200 redbull
    Pretty cool program clip is much easier then the Germans
  16. link
    link Gold Member
    339
    Hyrule
    Car:
    Clio 197 RB
    Here you go... Front internal aerial is #1396 somewhere behind the centre console.
    Wiring diagram back to the UCH...
  17. KenClioRedbull
    KenClioRedbull
    13
    Car:
    Clio 200 redbull
    I’ll have a crack at it after work I hate pulling apart my car...
    Link what about immobiliser would the Clio still crank
  18. link
    link Gold Member
    339
    Hyrule
    Car:
    Clio 197 RB
    I wouldn't expect it to crank no, but who knows. If CLiP shows a fault that's not fixed it normally shows a red dot next to the description, maybe the rear aerial works so it's detecting keycard but it needs the front aerial to run engine?? :confused:
    Worst case you'll need to find a new UCH, I'm presuming you've tried a spare keycard?
  19. KenClioRedbull
    KenClioRedbull
    13
    Car:
    Clio 200 redbull
    Spare card only have one ☝️ lost the other one ages ago.
    And the uch has to be new or can I reprogram a 2nd hand one .
  20. link
    link Gold Member
    339
    Hyrule
    Car:
    Clio 197 RB
    I think there reprogramable via CLiP but I dunno about matching keycards, there must be a way but dunno if CLiP can do it or not.
    Personally I'd chase the aerial fault till your out of all options, can't imagine it just throwing a random fault out if the UCH was dud. :think:
    Maybe the impact caused the wiring to come loose... Stranger things have happened...
  • Share This Page
