Clio 197 2007 Fuel Pump (Car Won't Start)
Hello,
I have a problem with my car which I believe is the fuel pump (diagnostic machine confirmed fuel pressure fault).
I am wondering if anyone can help answer the below:
  • How much is this likely to cost inc Parts + Labour
  • Where is the cheapest place to get replacement Fuel Pump? Is this a Renault Only Part? I believe the Part Number is 800685651
Any help would be appreciated.
Walbro would be a good replacement http://www.ebay.co.uk/itm/WALBRO-30...075526?hash=item4180ff1746:g:~FkAAOSwgQ9Vr6P5
Its not all that hard to DIY. There is access under the rear seats. Undo a large ring (ideally you need the right tool for this). Lift out the sender unit and replace the pump.
Sure it would only be about £50 if you get someone to do it.
Is the pump getting power? It might be best checking with a multimeter when you crank the car. Also fuel filter but I doubt it would be clogged that much to stop the car starting.
