Clio 197/200 engine mount kit... Upgrade
Discussion in 'Engine, Gearbox, Exhaust and Air Intake' started by Gez, Jun 20, 2012.
  1. Gez
    Gez Moderator & South Wales Rep
    Wales
    Boost Box
    Hi all,
    Just looking at the engine mounts upgrade k-tec do for the 197/200.
    They seem a good price for all 3 as a kit.
    Can anyone give any feedback on these items?
    Gez
  2. Foxspeed
    i have only the lower one!
    well made and fitted 100%
    more vibration but a lot less movement from the engine
  3. ryan197
    ryan197 POW right in the kisser Platinum Member
    same here
  4. MzM
    MzM
    5
    Sorry for my stupid question, but is the lower one on their site called:
    "lower stabilizer mount" ?
  5. Foxspeed
    yeh sounds like the one
  6. MzM
    MzM
    5
    Thanks!
    Do you think that if i place this non stock engine mount without telling the dealers, will my warranty become void?
  7. Foxspeed
    technically only they can tell you.....
    but if only the workshop notice it!
  8. Raptor6767
    Raptor6767 Gold Member
    Zagreb, Croatia
    Renault Sport Clio 197T
    How much more vibration?
  9. ryan197
    just a little extra vibration not too bad
  10. Foxspeed
    i quite like the added vibration....especially when cold - feels more like a "race" engine :thumbup1:
  11. fmp
    fmp Platinum Member
    982
    I have all 3 on mine.
    When cold there is some vibration, you can see it in the steering wheel.
    But once all up to temp they are no issues.
    Makes the car feel that little bit more responsive.
    I would fully recommend them.
  12. Sold them to me that comment :smiley:
  13. I also have all three. The upper engine mount cracked its mounting after 300 miles usage and ended in a horrendous knocking noise. This was returned to Vibra Technic and repaired FOC. So far the repaired unit has held up okay.
    If you think these give more vibration then try the 182 uprated mounts!
  14. Chrisgti6
    Chrisgti6 East Midlands Rep.
  15. 930Tech
    930Tech CLIO CUP groupee. Platinum Member
    North Nottinghamshire
    197 CUP and most of a 197 CUP race car
    These are the same as what the OP are talking about chris.
  16. Chrisgti6
    Ah right, fair enough. I didn't look at the Ktec ones first to be honest!
  17. Raptor6767
    Zagreb, Croatia
  18. Foxspeed
    on standard 197/200 there are 2 "engine mounts" and 2 "stabiliser bars"
    (cam belt) position mount l/h
    (gearbox) position mount r/h
    (sump pan) lower stabiliser l/h
    (cam belt) upper stabiliser l/h
    if you use the "k-tec" mount kit there are only 2 mounts and 1 stabiliser as the top l/h one isnt needed if the lower stabiliser is fitted
  19. Raptor6767
    Zagreb, Croatia
    Where does this torque link go?
  20. Foxspeed
    if you mean the lower one it bolts on to the subframe and to the drivers side support bearing housing for the drivers side driveshaft...
  • Share This Page
