200: Clean upper inlet...
CM200
Hey all!
Back again ;D
Was thinking of cleaning the throttle body today and was wondering if I could take the upper inlet off at the same time to give it a good clean as well.
However, I read on one post about having to fiddle with the pulleys if you’re doing this? Will I need a new gasket or is it fine to simply remove and then put back on? Not super technical in the engine department :tongueout:
Literally just want to clean it down, give it a scrub to remove a bit of corrosion/oxidation etc etc.
Once again thank you all for your time and knowledge <3
Throttle body and top manifold come off with out any fiddling with pulleys or timing, it comes off with 8 and 10mm sockets
The rocker cover on the other hand is a pulley off job
Reactions: CM200 and Sean197
Cheers man
Cleaned em both, throttle response and general pull feels better now!
Reactions: Gus
