Broken down near Manchester, specialist needed
Discussion in 'Clio 200 Area' started by wattson, Jun 10, 2018.
  1. wattson
    wattson Paid Member
    114
    Car:
    Clio 200 Cup FF
    I've momentarily over revved the engine by mistake and the car stopped running following a 'check injection' message. It won't start. I will now have the car towed to Manchester. I need the car back on the road Asap, can you please recommend a specialist? Many thanks.
  2. PAUL JA
    PAUL JA Paid Member
    502
    Car:
    Company shed
    Pav likes this.
  3. Big Ben
    4,847
    Herts
    Car:
    197
  4. Pav
    Pav Moderator
    10,995
    Manchester
    Car:
    albi blue 197 with boost
    as above..im away atm but give him a call..may be able to help..
  5. wattson
    wattson Paid Member
    114
    Car:
    Clio 200 Cup FF
    Thanks guys. I've got the car to Manchester to my mate's place. I'll try resetting the ECU just in case it's a simple problem, unlikely but worth trying... Failing that I'll contact Trevor.
    Pav likes this.
  6. sevenfourate
    sevenfourate Devotee of OCD Paid Member
    8,377
    Lowestoft, England.
    Car:
    Racing Blue RS-200 / Citroen C2 GT
    How / why do you think you 'momentarily over revved the engine' ? Most of these things spend their life bouncing off (Or running extremely close to) the limiter in every gear.....
    Good luck.
  7. wattson
    wattson Paid Member
    114
    Car:
    Clio 200 Cup FF
    Changed into wrong gear... Stupid, noobie mistake i know but it just happened...
  8. Dumdum
    Dumdum Gold Member
    264
    Car:
    Renault Clio RS200 CUP
    It will have maybe revved over the limiter, but in theory it shouldn’t have damaged anything as I’m guessing you realised in a split second unless you went from 6th to first at 120?
  • Share This Page
