Break Pad Sensor
Can anyone advise if there is a pad depth sensor on the front breaks that will trigger a warning light on the dash board. I have a meg 250, but I would assume the system is very similar on a FF Clio 197/200.....I have checked the manual and there is nothing obvious!
Nothing on the 197, pretty easy to check though. There will be a wire running from he back of one of the pads.
rs models with brembos dont have pad wear warning
only thing you will get is low brake fluid warning once the pads have got worn down but that assumes the fluid isnt topped up on services!
...break fluid was changed at the last service in September...but I have noticed that the pads are down to 5 ish mm and there is more break travel these days.....will probably change them after next pay day!
i never got this when my fuild was abit low
