Brakes question
Discussion in 'Clio 200 Area' started by Rick Voskamp, Jun 3, 2018.
  1. Rick Voskamp
    Rick Voskamp Paid Member
    34
    Car:
    Clio 3 Rs CUP
    Hi guys,
    I'm looking to buy new brake disc's including brake pads. The one i wanted to buy are Ferodo DS2500 brake pads for the front and rear, and F2000 brake discs from Tarox for the front and ''standard'' Bosch discs for the rear. I have experience with the Ferodo pads because they are also on my second car and feel good. But i'm going to use it quit offen on a circuit. Will this be a good setup? I've also seen the upgrades from K-Tec, but i think this is just too much for now.
    Greetings Rick
    (Pic of the disc)
  2. Big Ben
    5,023
    Herts
    Car:
    197
    Hi rick. I’ve used both ds2500 and ds1.11 on track.
    Ds2500 are good but can leave deposits on discs if pushed very hard.
    DS1.11 are brilliant. Only downside is they produce a lot of dust.
    Good luck
    Rick Voskamp likes this.
  3. Benno
    Benno Gold Member
    1,775
    Birmingham/North Wilts
    Car:
    UR 197
    Second this Rick. I've had a few passenger laps with people running DS2500 but the DS1.11 are a level above for track!! Get some pictures up of yours :smile:
  4. Rick Voskamp
    34
    Car:
    Clio 3 Rs CUP
    Thanks guys, but it's not legal to drive with de DS1.11 on the normal road is it? Do they brake good enough when cold?
  5. petercronin
    petercronin Paid Member
    323
    North East England
    Car:
    LY FF Clio 200 with Cup Pack
    I’m pretty sure that’s the same for DS2500’s too. 1.11’s are fine when cold and waaayy better when hot, they also don’t ruin your discs like 2500’s do.
    My vote would be 1.11’s every time out of those two. And the standard discs are fine to use.
  6. Rick Voskamp
    34
    Car:
    Clio 3 Rs CUP
    Thanks for the reply, i will dive in to it
  7. Micah
    Micah Clumsy McButterfingers Moderator
    2,621
    Kent
    Car:
    Clio 220 Trophy
    I use 2500's on the front with standard discs and they're very good, though I now need to check them for deposits!
    The 1.11's are mighty on track - I was nearly sliced in half by the seatbelt under braking in @Big Ben's Meglio! Incredible pad but just make sure you clean your wheels after every track day.
    Big Ben likes this.
  8. PAUL JA
    PAUL JA Paid Member
    503
    Car:
    Company shed
    I concur with the above, DS2500 are troublesome when pushed hard leaving deposits on the disk. DS1.11 are a vast improvement, however I would still say that Pagid RS29’s are a better all rounder (they are expensive though !)
  9. Rick Voskamp
    34
    Car:
    Clio 3 Rs CUP
    I contacted my local dealer this afternoon but the die not recomended these pads to drive on the normal road.. They said bits will come off because they won't get to the optimal temperature. Are those your experiences as well?
  10. PAUL JA
    PAUL JA Paid Member
    503
    Car:
    Company shed
    We've run Ds1.11 and RS29 on the road with no issues
    It's not a major job swapping disk and pads
    You could run road disks and pads I.e. Brembo or similar and then use a better disk and track orientated pad when on track
  11. Rick Voskamp
    34
    Car:
    Clio 3 Rs CUP
    Yes that's true, ds1.11 front and rear on track?
  12. peter
    peter POTM Winner - February 2017 Gold Member
    1,209
    b e l g i u m
    Car:
    RB7 #166
    another DS1.11 user here. brilliant pad on track and absolutely no problem using them on the road. brembo HC discs (coated) and quality brake fluid is all you need on these cars.
    J M W, Sean197 and Rick Voskamp like this.
  13. Rick Voskamp
    34
    Car:
    Clio 3 Rs CUP
    Thanks! Are those discs for the front and rear available? Or do you run standard discs for the rear with standard pads?
  14. PAUL JA
    PAUL JA Paid Member
    503
    Car:
    Company shed
    We used only a mild pad upgrade at the rear Mintex 1144 on standard disks
    peter likes this.
  15. peter
    1,209
    b e l g i u m
    Car:
    RB7 #166
    standard discs on the rear, with galfer FDRT1066 pads for now (i bought them together with the fronts). will switch to something different pads, when the galfers are done. not sure to what yet, though. standard discs are fine on the rear.
  16. Rick Voskamp
    34
    Car:
    Clio 3 Rs CUP
    Alright, i might go for DS2500 on the rear and standard disc. Front will be Brembo HC discs with the DS1.11 pads.
    peter likes this.
  17. ///M
    ///M Gold Member
    4,931
    Car:
    R27, ///M CS, Exige V6
    Godspeed are also an option if you want a good upgrade but don't want to stretch to the expensive KTR kit.
  18. dr gonzo
    dr gonzo
    42
    Car:
    clio 3 rs cup
    Just put megane 3 rs calipers and discs with endless brake pads and motul rbf 660 brake fluid :grin:
    john_walker74 likes this.
  19. dr gonzo
    dr gonzo
    42
    Car:
    clio 3 rs cup
  20. nick's
    nick's Platinum Member
    562
    Walsall
    Car:
    200 Silverstone GP
    Do they go straight on
  • Share This Page
