Any wider wheels about
Oz ultras do an 8J wheel. Make sure you get one with the right offset or they will stick out too much...
Yeh just fill the arches out either 7.5 or 8 inch with the correct offsets. Like I say if there's nothing about a set of 20 mil spacers will have to do with my wheels.
I do like the pro 1.2s though.
Depends what you are after. Spacers obviously will give you the stance look you may be after but remember longer bolts are needed too.
A wider wheel will allow the option to run a wider tyre to be installed but will gain extra weight in some cases in wheel & tyre.
Cup racer 8Js weigh around the same as the standard 7.5 road wheel with the same ET68 but increase width by half an inch.
Aftermarket will offer a more aggressive offset and lighter choice.
A few used wheel options here, depending on budget.... 15% off the ATS black set until tomorrow. Code ATSGTR15.
https://www.apmotorsport.co.uk/clio-3-rs
Some nice stuff for sale in that link. Those GTR wheels are stunning ! And there’s enough parts for sale to keep a Cup Racer wannabe happy for many a pay day....
**White Cup Racer wheels at £75 each are cheap if you can muster up 4 good, straight ones.
I got excited about the Cup Racers until I saw they only had 2 in stock..
