Accelerator / Clutch pedal.?
is it just mine or what guys, ?
when i press the clutch or accelerator pedal in sometimes it makes a click/tick noise, it dont do it all the time but quite often tbh, :worried:
i find myself turning the stereo up louder so i cant hear it lol, :lol:
what is it, ?
Re: ACCELORATER/CLUTCH PEDAL ?
I believe it is something to do with the speed limiter or cruise control. when using either and the clutch is pressed it over-rides the function - I think
My clutch pedal has the most annoying squeak!
When I release the clutch... SQUEEEEEAK!
Feel like I've got a worn out mattress spring as a clutch pedal...
I looked behind the pedal, can't find a spring, so didnt know where to lube, ANY ideas?!
the clutch pedal has a switch on it hence the "click" - this is for the keyless start and override on the cruise/speed limiter
thanks guys,
so i have nothing to worry about then, :smiley:
@ carlo, not to sure about your squeek tho mate, ?
that click and squeek make me want to cry :<. I got under there and greased everything up which has made it much better, but now the click is coming back a bit more. The fact that i can feel the click through my foot makes me so angry, lol. Nothing gets me more than squeaks and creaks.
there was a recall on some clio i think for faulty pedal switches - either the switch was faulty or the switch was fitted wrong
its strange that some cars have louder clicks than others - you would think they would be all the same.....makes you wonder if there is an issue ?????
mine isnt loud, but being a new car to me i listen out for every noise,sound,ticks,squeeks lol,
i have got used to it now i know it aint a problem,
coming from a Fiesta ST you get used to the rattles and squeeks anyway, lol
