#342
Discussion in '20th Anniversary Edition Register' started by duck.co.za, Jun 8, 2018.
  1. duck.co.za
    duck.co.za Paid Member
    52
    Cape town
    Car:
    Ferrari 308 , BMW Xline X3 , Clio RS 200 20th anniversary
  2. duck.co.za
    52
    Cape town
    Car:
  3. SeanTheSheep
    SeanTheSheep Paid Member
    419
    South Wales
    Car:
    Clio 200
    Very nice :smile: enjoy her
  4. duck.co.za
    52
    Cape town
    Car:
    Thanks , is yours a Cup ? If you look carefully the motor is in pieces on the bench behind :disappointed:
  5. SeanTheSheep
    419
    South Wales
    Car:
    Clio 200
    Oh yes! Didn't even notice first time round.
    Why is this? You rebuilding.
    Mine is not a cup model btw
  6. duck.co.za
    52
    Cape town
    Car:
    Don't know Clio's very well , but those are cup wheels ?
    I bought it with the motor in pieces . Looks to have run a bearing . Engineering shop also said bores were oval !! When I measured them they didn't seem to bad . Going to rebuild myself , maybe lighten a few bits .
    SeanTheSheep likes this.
  7. SeanTheSheep
    419
    South Wales
    Car:
    Clio 200
    Mines on cup dampers & springs and has the cup alloys but it's not a "cup" model, someone correct me if this is not the case
  8. duck.co.za
    52
    Cape town
    Car:
    Cup has a plastic /cheap dash ( lightweight ) I think .
  9. Pav
    Pav Moderator
    10,869
    Manchester
    Car:
    albi blue 197 with boost
    welcome :french:
  10. duck.co.za
    52
    Cape town
    Car:
    thank you
  11. Marsch
    Marsch
    583
    Berlin, Germany
    Car:
    Stealth Grey RS 200
    At first congratualtions to the car.
    The ones on yours are Cup rims. Presumably the 7,5x17 ones. There are also 8x17 ones from the motorsport Cup Clios existing but they aren't road legal from what I know (at least not in Germany).
    From what I know your version should have actually come with Bebop rims (see the overview link in my signature) but maybe the Cup ones were an extra option.
  12. duck.co.za
    52
    Cape town
    Car:
    Thanks for the reply
    It seems to indicate 20th anniversary ! But seems to have some of the options of the Edition 20 . Like the rims and red calipers
    I did buy it from the first owner and I don't think he changed anything , may be he specked it like that at purchase time .
  13. Marsch
    Marsch
    583
    Berlin, Germany
    Car:
    Stealth Grey RS 200
    No problem.
    Red calipers are normally an indication that the car has the cup suspension/pack but there are also exceptions to this. Of course the red calipers could also have been added later on or just got resprayed for the looks. But if you say you think it came like that I'm not doubting it as there are so many different specs for different countries that it just gives me a headache. I'd say not even the guys in Dieppe could answer what they've thrown at which car exactly.
    There's also a 20th Anniversary Limited Edition for Australia existing which isn't mentioned in my overview. It was limited to 30 cars and has an own badge similar to the Editon 20. I've the impression by now that the 20th Anniversary Special and Limited Edition are actually the same and just got marketed under a different name with slightly different specs. It's simply confusing.
    After a short search I've found this youtube video with still shots of the ZA 20th LE and it looks exactly like yours.
    So I'd guess you're right when you say it came like that.
  14. duck.co.za
    52
    Cape town
    Car:
    Impressed , really appreciate the info
    Mine is the pearlescent white , not sure if that makes any difference .
    Can you point me in the direction of an 830 or 832 engine rebuild . All I can find is the 172 and 182 .
  15. Marsch
    Marsch
    583
    Berlin, Germany
    Car:
    Stealth Grey RS 200
    Please note that I've slightly edited the info about the Australian version above.
    I'm trying to collect infos about the special editions but I'm getting more confused as deeper I delve into this matter.
    The colour code should be TE QND for all 20th versions. The direct translation is "Pearlescent Frost White" but from what I got it's actually "Ice White" for the English (speaking) market(s).
    Sorry, can't help you about the rebuild but there are some knowledegable guys around here that surely can hook you up. The only thing I know is that you should change the bearing shells of the crank shaft if you're with it as the original ones are just pressed in. They've the tendency to turn in their sockets which leads to blocking the oil flow (feeding holes) with the respective result. Switch them to some with a "nose" and rework the block accordingly (key and slot/tongue and groove principle).
    Something like that.
    [​IMG]
  16. duck.co.za
    52
    Cape town
    Car:
    learning all the time , thanks
  17. Marsch
    Marsch
    583
    Berlin, Germany
    Car:
    Stealth Grey RS 200
    Me too. Actually even during our conversation here. See the part about the colour in the last post above that I've just added.
    Didn't knew the colour is called "Ice White" in English so far.
  • Share This Page
