275 RS megane trophy
Few people having grief with the 275's. I see one guy fighting Renault to hand his back.
Yours ok I assume Foxy?
it is been fine since the boost pipe incident!
only thing that I am pissed at is the corrosion on the casing of the ohlins...they look 12yr old!!!! wasn't expecting that on such a premium/costly option
Nice one Mark, sounds like an excellent day to me!
So what is the problem with the 275s then? I'd assume that as it's the outgoing model all the issues would have been ironed out and not vise versa.
Foxy this is shocking mate. Isn't the case aluminium or at least a premium anticorrosion steel? Your car is months old..
outer casing are supposed to be a shiney type of coating...its all corroded off in less than 5 months...(fronts are bad - rears not so bad)
Si I've spoke to a few chaps about the corrosion and they well protected have you heard of any other's going the same way?
