When new you get three new screws, slightly longer than the ones you remove from car and nine pop rivets per side to hold it on. plus the one locating lug per side.
Remove the three screws, drill three holes in the three lugs sticking out and screw up with the three longer screws.
Next is the scary bit, drilling the hole for the locating lug at rear end.
When those two are done, drill and fit the 9 pop rivets.
Sounds easy, takes a bit longer.
